Beveled porch railings
Old 08-24-18, 06:15 PM
B
When I started rebuilding my porch, I wondered how I was going to avoid repeating the problem of the spindles on the railings rotting out at the bottom. Then I saw that someone had bottom rails that were beveled, perhaps 15 degrees so they had a crown. The spindles had matching V-shape cut into the bottom end. Brilliant, they've solved it. That was months ago and I haven't worried about it since.
Now that I'm ready to buy and install the railings, I can't find them anywhere. Menards and Home Depot have never heard of them. All my searches turn up spindles with flat bottoms.
Any ideas where to look, or what to search on?
Thanks, Brad.
Old 08-24-18, 07:05 PM
Received 77 Votes on 72 Posts
Going to have to go to a real lumber yard for something like this.
The older the better.
Around here it's called the Richmond Rail.
Even the top rail has a pitch.
Portsmouth Lumber Corporation
By adding a real location in your profile someone may be able to suggest someplace local to look.
Old 08-24-18, 08:26 PM
XSleeper's Avatar
Received 676 Votes on 625 Posts
Found one site that answers your question. https://www.vintagewoodworks.com/slopbotrail1.html
Old 08-24-18, 10:07 PM
B
xsleeper That is exactly what I'm looking for.
Interestingly, I thought once I found one, I'd have the correct terms to be able to find dozens.
But searching on 'notched spindles' or balustrades return nothing of substantial.
'Sloped-top rail' had the same lack of results.
But one is enough. 8: -)
They even have instructions for how to cut them. Now if I only knew someone with a radial arm saw.
Thanks again!
Old 08-24-18, 10:22 PM
B
Joe,
Looks promising but I don't see that they have the matching spindles.
Old 08-25-18, 05:00 AM
XSleeper's Avatar
You can make a jig and use a table saw along with the sliding miter gauge.
