How to install pavers around deck posts
Old 09-07-18, 09:13 PM
Q
Question How to install pavers around deck posts
I'm installing pavers under the deck, which has 5.5x5.5 wood posts running into dirt. Should paver blocks contact posts or keep enough gaps? I worry about the moisture and rot of the posts. I guess if the blocks contact the posts, the moisture will be trapped, so rot goes quicker and earlier. If the gap is wide enough, the bottom of posts will be drier. What if I let blocks contact posts and seal the seams? I'm not sure which one is the best solution. Please give me some advice and explanation. Thanks!
Old 09-07-18, 10:14 PM
Received 98 Votes on 86 Posts
They're buried in the ground so it's too late to be worrying about that.
Old 09-08-18, 02:06 AM
XSleeper's Avatar
Received 942 Votes on 860 Posts
Might as well leave it uncaulked so it can dry out.
Old 09-08-18, 04:32 AM
Marq1's Avatar
Received 505 Votes on 468 Posts
Posts are in the ground so having the pavers touching is nothing worse.
Just trim them up with a gap and fill with your paver sand, all is good!
Old 09-08-18, 08:20 AM
Q
The deck was build by previous owner. I know it's not very good to bury posts into ground. However, probably I'm not living in the south. most decks here are build in that way.
Old 09-08-18, 07:27 PM
Q
I want to leave a gap between the post and the paver. Perhaps the gap will not look very good. I don't know whether I can add a low profile post skirt to cover the gap?
