Advice on winterizing screened porch.
Old 09-17-19, 08:56 AM
In the next month I plan on winterizing my porch using 20 gauge vinyl plastic using 3/8" or 1/2" grommets. The issue I forsee is finding screw heads large enough to fasten with those size grommets. My initial thought was to use some type of washer, but after a quick look in the depot I'm not seeing anything useful. I could go down to a 1/4" grommets but I'm concerned about durability in that size with winter winds and holding up.
I'll probably be using a 3/4- 1" stainless screw and would like some advice before I proceed further.
Thanks
Old 09-17-19, 09:12 AM
Received 184 Votes on 171 Posts
What type washer are you looking for? I'm guessing a fender washer will do what you want. Also, "the depot" isn't the only source of hardware. There are many other suppliers with much better selection.
Old 09-17-19, 11:09 AM
XSleeper's Avatar
Received 184 Votes on 173 Posts
Look for stainless truss head screws. I don't see the plastic holding up around the grommet, even tarp grommets don't last long.
Old 09-17-19, 01:39 PM
Xsleeper, im reinforcing the edges so it holds up.
