How to smooth this brick walkway
Old 10-05-19, 12:19 PM
C
Received 15 Upvotes on 14 Posts
i would like to fix these bricks so they are flat once again. I assume the nearby trees have grown roots that have raised these bricks. Can I just remove the bricks and then cut out all the offending roots? I want to think the trees will not die as a result. I am hoping there are enough other roots to keep them alive. Am I being naive or too simplistic?
Note the root in the second photo. It is between two of the bricks in the center of the photo. I am assuming there are many more throughout this area.
Old 10-05-19, 02:54 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
Trees will be fine, not a lot of important roots at the top of the ground!
