Deck to Patio Transition (Stairs)
Old 11-18-19, 12:12 PM
G
Received 2 Upvotes on 2 Posts
Hey All,
I want to install 2 steps down from a raised deck to a ground level patio (not built yet).
How can I protect the bottom of the stringers from moisture?
I could set the stringers on the ground, concrete, or the patio itself, but either way, its still going to be exposed to any moisture collecting at the base.
Old 11-18-19, 01:20 PM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
Just like millions of other decks. Use pressure treated wood that is rated for ground contact.
Old 11-18-19, 01:26 PM
G
Yes, that was the plan. I was hoping for even more protection though.
Old 11-18-19, 01:43 PM
XSleeper's Avatar
Treat the cut end with Copperkote or Anchorseal2.
Old 11-18-19, 02:04 PM
G
Thank you very much!
I will look into it.
Old 11-18-19, 02:13 PM
Received 295 Upvotes on 265 Posts
Do not put them directly on the ground as they will sink in over time.
Also a good idea to cut an old shingle and put that under them especially if on concrete as it prevents moisture from wicking up.
Baldwin voted this post useful.
Old 11-18-19, 02:18 PM
G
Also good information, thanks!
