Joist hanger placement
Old 11-22-19, 04:30 AM
P
Received 1 Vote on 1 Post
Hi all.
I am going to install a small deck (4.5 x 4 Meters) that will go between 2 walls. The brick house wall and the brick garage wall opposite.
Question is in regards to the joist hangers.
I am assuming that i should attach a wooden beam to the wall first and then the joist hangers to that.
Can you just attach the joist hangers straight to the brick?
Also how far apart should i place the joist?
Old 11-22-19, 04:52 AM
Received 330 Votes on 293 Posts
Welcome to the forums!
I don't think you're allowed to connect the hangers to the brick, in fact most brick facades are just a veneer and won't support addition load. Normally floor joists are on 16" centers although that is somewhat dependent on the type of decking you intend to use.
Old 11-22-19, 05:13 AM
P
Received 682 Votes on 629 Posts
The problem is there is no good way to attach joist hangers to masonry so you first need to bolt a rim joist to the brick.
Old 11-22-19, 05:16 AM
P
Thanks for the info guys.
Was thinking as much. More i thought about it.
Old 11-22-19, 05:44 AM
Unless I'm mistaken you can't secure the rim joist to the brick - it needs to be bolted thru the brick into the house's rim joist. Installing a freestanding deck is another option.
Old 11-22-19, 05:53 AM
XSleeper's Avatar
Received 714 Votes on 661 Posts
Correct. It is against code to bolt a ledger through brick.
Old 11-22-19, 06:33 AM
Received 158 Votes on 145 Posts
Spacing of joists depends on what material your decking is and how it is running.
Also I never bolt a trim joist directly to a wall, I always use spacers.
