What primer to use between carpet glue and paint?
Old 11-24-19, 11:17 AM
W
I have a covered concrete patio which had outdoor carpet for about 10 years. I've removed the carpet and used a floor scrapper to remove the peaks of the glue. The glue is well attached and I would like to paint it, with the understanding that I will see the irregularities through the paint. I plan to use Behr Porch and Patio paint (which is latex), and am considering applying Kilz Original Primer (which is oil based), in the hopes that the primer will reduce the visibility of the glue texture through the paint. Will the primer help? Thanks!
Old 11-24-19, 04:19 PM
Marq1's Avatar
Received 364 Votes on 340 Posts
First off, the paint, even the primer, is not going to work will with adhesive residue, it's not a stable substrate and you will be creating a big mess!
Plus I cant even imagine just painting over glue, it's going to look horrible!
joecaption voted this post useful.
Old 11-25-19, 02:11 AM
Received 313 Votes on 279 Posts
While it's ok to paint over minute particles of glue you don't want to paint over a bunch of it. Scrape off what you can and use a solvent to dissolve the rest then pressure wash.
Old 11-25-19, 07:19 AM
Received 77 Votes on 72 Posts
https://www.jondon.com/bean-e-doo-mastic-remover-4.html
Please go to a real paint store, not a box store and ask them what to use.
That's all they do and will know what will work.
Old 11-27-19, 07:19 AM
T
Received 13 Votes on 11 Posts
You need to rent a concrete sander and get that floor sanded down nice and clean.
Old 05-16-20, 09:42 AM
W
I went ahead and did this a few months ago. I used a scrapper to remove the highest points, primed and painted. It took about 10 days for it to stop feeling sticky, but it seemed fine after that. It is slipper when condensation forms, but that hasn't been very often. Only time will tell if it lasts. You can definitely see the glue patterns, but it looks OK to us.
Old 05-16-20, 04:46 PM
Received 94 Votes on 83 Posts
Thanks for the update - always nice to hear the end result of the questions asked.
