Deck Extension to Above Ground Pool Questions
Old 04-07-20, 10:13 AM
B
I am building an extension onto my existing deck that will come out to a 24' diameter above ground pool.
The existing deck is 12' x 12' and attached to the house.
I want the extension to be freestanding - but at the same time - attached to the existing deck to create a seamless transition (it should "feel" like it's all one deck, maybe with a slight 4" - 6" step down to second level)
Attached are photos of the existing deck and the area where the extension will go, along with a quick sketch of what this will look like with some rough measurements.
I have a good bit of carpentry experience (e.g., have built privacy fences, tables, shelves, etc.) and have all the necessary tools to DIY this.
That said, as I am starting to plan this out, it does seem a little bit trickier than just building a standard ground-level deck. I want to make sure I am using best practices and following a sound set of plans that provides a solid structure and meets 2012 international building codes.
I am in the Nashville, TN area. Where/how would be the best way to get a rough design/plan and material list to follow that would get me started on DIY'ing this project?
