wash or sand deck first before restaining?
Old 05-30-20, 09:49 AM
Received 1 Vote on 1 Post
My deck needs to be restained as it has been a number of years since it was last stained. I plan on sanding and washing the deck before I restain. My question is in what order do I sand/wash? Do I sand the deck first and then wash? Or do I wash the deck first and then sand? I'm reading differing opinions online. Thanks.
Old 05-31-20, 01:04 AM
Marq1's Avatar
Received 395 Votes on 369 Posts
If sanding then you would clean afterward!
Old 05-31-20, 03:03 AM
Received 330 Votes on 293 Posts
It would help to know a little more about your deck and the stain you intend to use.
I rarely ever sand a deck, cleaning is usually sufficient. If you were to sand it all down to bare wood you could likely skip the cleaning.
Old 05-31-20, 05:52 AM
Norm201's Avatar
Received 255 Votes on 229 Posts
Depends how bad the surface is. Usually a power wash is sufficient.
Send a few pics.
Old 05-31-20, 03:45 PM
Here are a couple of pictures. I plan on using Behr semi-transparent stain & sealer. Oil-based. Deck is spruce. Probably 10 years old as the house was built in 2008, but I am not the original owner.
Old 06-01-20, 03:56 AM
I'd wash it down either using a bleach solution or a commercial deck cleaner followed by a wood brightener. Once it dry it should be in great shape for any semi-transparent deck stain.
Shepweiler voted this post useful.
Old 06-13-20, 05:05 PM
(sanded some areas, washed with cleaner, then stained)
Norm201 voted this post useful.
Old 06-14-20, 04:23 AM
Looks good ,,,,,,,,,,,,,,
