Cottage improvements
Old 08-01-20, 05:15 AM
B
Hey guys I am hoping you folks can help me out. My wife and I want to hide these poles with some sort of decorative wood box around each pole, removing the old hand rail and replace with thick 1 1/2 inch braided rope to feed through as our new railing 1. Poles are a little \"wobbly" 2. Runs down a slight hill about 50 FT
Old 08-01-20, 06:03 AM
W
Received 16 Votes on 15 Posts
I would remove rail and posts. Install wood posts with hole near the top of each post large enough to allow the rope to pass through. Just my 2 cents. Good luck with your project.
Old 08-01-20, 06:19 AM
Received 270 Votes on 239 Posts
I doubt any decorative box will do much to fix the wobble. I agree it would be best to remove the posts/rail and install ones you like - set securely in the ground.
Old 08-01-20, 05:55 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Beautiful space....Remove what is there and start from scratch. In this case retrofit will do nothing but give you headaches. Do it right the first time and you don't have to redo down the road. Check into local code so that the rope is at the appropriate height.
marksr voted this post useful.
