Lumber heavy from moisture
Old 08-11-20, 09:25 PM
A
It seems like some of the 2 X 6's that I buy have more moisture content. Is it good practice to let wood sit in the sun for a few days? I'm using my wood for a patio cover. The less weight the better.
Old 08-11-20, 09:30 PM
XSleeper's Avatar
Received 673 Votes on 622 Posts
Unstacked wood will often warp as it dries out, so you would be wise to install it asap. It can dry after you have it installed.
marksr voted this post useful.
Old 08-12-20, 04:42 AM
Norm201's Avatar
Received 230 Votes on 205 Posts
Is it treated wood? If so it wouldn't make much difference.
Old 08-12-20, 10:54 AM
A
Not treated. Douglas Fir. I'm cutting it down to 1 X 1's. Already been drying for 2 days now. Heat wave on the way so they'll dry out more if they can.
Old 08-12-20, 10:59 AM
Received 319 Votes on 283 Posts
As noted above if you nail it down while still wet it will lessen the likelyhood of it warping. If you want to air dry it first you need to stack it with spacers between the boards [for air flow] that can take up to a yr although most of the drying is done in the first 3-4 months.
Norm201 voted this post useful.
