One year ago, we had our balcony deck replaced by a professional deck company. The deck is vinyl on plywood with PT joists. A few months ago, we noticed discoloration on some of the plywood under the deck near the sloped edge. We were worried that the vinyl surface was leaking. The contractor assured us that this was residual moisture from the install and didn't indicate a leak. He said it was just a little mildew because we live on the west coast in a humid climate. Since then, the discoloration has spread significantly, and it looks like water damage. The plywood doesn't necessarily feel wet to the touch, but we are still concerned this might represent a leak. It is largely confined to the plywood at the sloped edge, but there are also spots elsewhere.
Has anyone seen this before? Could it be simply "residual" moisture from installation? What is the best solution, here? The contractor told us just to treat it with a bit of anti-mold solution. Thanks in advance for any opinions or advice.
If we had a clue what the top and edge looked like we might be able to help more. I suspect the contractor is feeding you a line. Residual moisture? Was it pouring rain when the installed it?
One way to be sure, is to get a moisture meter and compare the 'wet' spots to the dry spots. A sheet of plywood should have the same moisture reading in both spots based on the moisture in the air and such.
Thanks for your replies. It was raining when it was installed. They had tarped the entire top.
The contractor brought a moisture meter and said the reading on the discoloured spots were the same as on the rest.
Vinyl top looks good. I've gone over it and the seams carefully and can't find any holes. The vinyl edge hangs over 1.5 inches or so and has a lip to shed water away from siding.
We really need to see some photos where the deck meets the house from above and below. We want to see how the deck is attached to the house and how they flashed and did the siding in that area.
I bought this house about 1 ½ years ago, and I've always contemplated on what I wanted to do with this porch. Is there a way I can turn it into a year round usable area? From what I can tell it isn't secured to the house, so I wasn't sure if there was a way to seal it without completely removing the structure and starting from scratch. I was also curious on how I would be able to insulate the floor and put a subfloor down with hardwood on top. Any kind of info or ideas are all appreciated. Thanks!
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183025_4ff0965a4a2fc7595f8736fec18d62932582dbb0.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183029_84192462bc255e01e0d42050cf1f07a1e9930b94.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183033_3195bb6fc23adcd9f96c09a721147f9f375229c3.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183043_fe8c0e33805cc056e61015d7aef51ed1e110fdaa.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183051_cde8d74baeff35a25e601127ebab5d01564b71d4.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183107_3095f02b8fee63aa324cefa219c6c4e925caa1ef.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210121_183118_e8caeb71d8433191e9b0c01ed78b8b5e1b610271.jpg[/img]
So we live near a 2 story house and even tho nothing crazy going on in my patio I prefer privacy and trying to find a way to cover some of my screened enclosure to add privacy from the 2story house next door. Was thinking of getting some Coolaroo roller shades from home depot (linked below) however these are of course not fully private but I think that would suffice. The issue I have is that a portion of my screen is a trapezoidal shape so these wont really work in that spot. My father suggested a piece of thin metal painted black and screwed into the top portion but wanted to see if there are better ideas out there im just not thinking of. Any help is appreciated. And yeh I know this is a bit extreme but still something I would like to look into. Thx!
Example of the roller shade
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x1001/a1iwli5msdl_ac_sl1500__a7bd24af6f86fe22e2efcdd01e03f14d820e48b0.jpg[/img]
Pics of the screen area
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210128_181544_df0e1d221c749d348d1e3d0e4ab012cb145b82a6.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210128_181554_de67a4d679b0a7e1f5ff688d7cad9ed7084b1a8f.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210128_181608_2086b4183654913352321ec5251e00a76efa060b.jpg[/img]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20210128_181609_daeafe5fc126c06c59a932d4fabf25da58b12914.jpg[/img]
