Killing moss on rough concrete dock decking
Old 01-27-22, 10:32 AM
B
Received 5 Upvotes on 2 Posts
Prefer not to pressure wash it. Is there a product I can spray on it that will kill it?
I'd prefer not to use round up. Any suggestions?
Old 01-27-22, 11:01 AM
2
Received 361 Upvotes on 312 Posts
Wet-And-Forget might work. Multiple applications and scrubbing with a hard bristle broom.
Old 01-27-22, 02:27 PM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
A mild bleach solution will clear it up.
Old 01-27-22, 02:42 PM
B
What parts bleach to water?
I see that Wet and Forget as well - looks intriguing.
My concern with the bleach is will it make the area slippery upon application? The moss currently when wet is a little slippery when wet.
Old 01-27-22, 03:29 PM
P
Received 1,956 Upvotes on 1,752 Posts
I use a 1:4 bleach to water solution for heavy growth or in hot summer when it evaporates faster. In cooler weather and lighter deposits I use 1:6ish.
Yes, wetting moss will make it slippery and adding super slippery bleach doesn't help but bleach works best at killing it. For a less slippery option you can use an iron sulphate solution but it causes slight rust stains which might be a nice look since it can look a bit like stained concrete.
Old 04-27-22, 09:26 AM
B
Bumping this thread as I'm still looking.
I talked to Wet and Forget and they don't recommend using near water - to stay away 100 feet.
Since the moss is on concrete docks I need something that if it got into the water (ocean) would be safe.
Old 06-04-22, 09:39 AM
Y
Received 24 Upvotes on 23 Posts
I used W&Forget on some concrete paving stones with moss. Worked great in 2-3 days. I am not near water and see the warning on the label. Nothing about ocean runoff. Why not do it on a clear day with no rain for a few days.
