What tool do I use?
Old 04-09-22, 08:58 AM
E
What tool do I use?
Hi all,
I’m repairing my lattice screen on my deck and need to also repair a few 2x4’s. I’ve checked around and I guess no lumber stores have the pre-drilled 1/2 inch deep grooves that the lattice sheets sit in. I don’t know what the tool is called and am hoping someone here can help.
thanks,
Rob
Old 04-09-22, 09:33 AM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
Never knew that there was a specific groove for lattice work.
Just use a circular skill saw and run a groove along the length. You may have to make two passes.
Old 04-09-22, 09:49 AM
P
Received 1,951 Upvotes on 1,747 Posts
You could also use a router. Choose a bit the appropriate size for the slot you want. You will also need a guide fence to keep your slot straight.
Old 04-09-22, 09:51 AM
Received 785 Upvotes on 688 Posts
I'd use a table saw to cut out the rabbit. IMO that's the easiest safest method.
Old 04-09-22, 11:01 AM
the_tow_guy's Avatar
Received 198 Upvotes on 158 Posts
Yeah, HD and Lowes both used to have it; looks like it's been dropped from inventories:
https://www.lowes.com/pd/2-x-2-x-8-L...ng-Cap/3048182
Old 04-11-22, 11:52 PM
Yeah a router or do it manually with a saw
Old 04-12-22, 05:21 AM
Received 126 Upvotes on 111 Posts
I tried that stuff and hated it.
Vinyl lattice expands and contracts a lot with a change in temp. and it tends to pull out of those pieces because there's no way to fasten it in place.
Please post a picture of what your trying to deal with.
Most often I've seen it installed incorrectly.
Old 04-21-22, 09:08 AM
E
Thanks all, I appreciate your comments. I decided to install a different wall, as there is no cedar lattice sheets around here.
