DIYer looking to attempt a deck extension... tips welcome!
Hi All!
I'm a amateur interior DIYer who has a remodeled 5 rooms in my house (to the studs, wiring, insulation, carpentry, drywall & mud, sand & paint, trim, etc)
This year I'm going to attempt my first exterior project: a deck extension in my back yard. I would love to get some suggestions and advice from seasoned pros like yourselves. I'm specifically looking for design ideas and also any points to keep in mind as a first time deck builder. For example, what are common mistakes amateurs make so I can avoid them myself.
Here are 3 pics of the current deck.
My initial idea was to do a tiered extension and I've drawn up some rough plans. I want to remove the existing floor boards on the top level and have everything be TREX. I'm not sure what to do for railings.
Biggest mistakes they make are not educating themselves before starting, not having a solid foundation, not building to code, not getting permits and not having inspections, where required.
Best starting point is to Google and download the AWC DCA6 prescriptive deck guide. Familiarize yourself with those methods and you will be on the right track.
From the pictures I'd suggest scrapping the idea of expanding and just start new. Anything you do will be compromised by the current design, and it doesn't appear it's too new, too large that it's going to make a significant contribution.
Also, don't go cheap, think composite decking materials. Yes it's a cost up, but in the long term it will save you money and hundreds of hours of maintenance. No replacing boards, no staining, no sanding.
I'm on year 13, maybe 14 with my full composite deck, an annual spring clean up and it still looks like new..\
[b]Hello all.[/b]
I’m looking to build a small deck (9’7” x 8’). It is positioned on an inside corner of our house. As such, Im looking to have a double ledger board with one footing placed near the un-supported corner, which our code officer has told me would be ok.
The footing would support a beam that would run UNDER the floor joists and HANG from one of the ledger boards against the house. Both the beam and the ledger are constructed from 2x8”s. I found a Simpson Strong-Tie HU Galvanized Face-Mount Joist Hanger for 4x16 Nominal Lumber, which would fit, but seeing as I’m not using it quite as intended (to face mount a joist to a ledger), I’m not sure it would be to code.
Does anyone know if this would be adequate or have another solution? Thanks in advance!
Best,
Nicholas
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1646x1600/deck_6a734b7fe17c3aadfc37f0ca8790ee0521d2bc3b.png[/img]
Read More
and looking for advice. the old stuff rotted out. I'm planning on treated stringers, PVC stringer and riser wrap so it should be good there. as for treads, I want to use the 11"X1" southern yellow pine treads I used last time (and have elsewhere on the house to good effect), but thinking of leaving a gap at the rear to allow for drainage where it joins the riser. and a 1" overhang on the front with the bullnose. is the gap at the back a good idea? this is where the rot was last time. it accumulated with nowhere to go. I figure if it can drain down and drip off the bottom of the PVC riser there will be no issues. does this make sense? thanks as always. Read More
