Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Decks, Patios, Porches, Walkways, Driveways, Stairs, Steps and Docks
Reload this Page >
Securing a garden screen on half a porch in a rental home, without huge impact
Old 04-24-22, 11:34 PM
AlfredoB's Avatar
Question Securing a garden screen on half a porch in a rental home, without huge impact
We've just moved in to this rental. It has a 15 x 5 metre porch on the back. This photo is of one end. We are slowly tidying up the stuff temporarily dumped on the porch.
Where the little workbench is on the right, we'd like a screen or partition to hide the work/gardening area from the house out to about 4m.
BUT we can't really do a lot of damage to the house, porch or concrete.
Now we get to the questions:
-- What are ideas for putting up a screen that won't blow over in the wind etc?
-- Anchoring ideas that won't show (or won't show much) after removal?
Old 04-25-22, 04:14 AM
Norm201's Avatar
Received 694 Upvotes on 617 Posts
Using ceiling hooks to hang a curtain or screen will most likely be the least obtrusive. It could be weighted down with bricks on the floor to prevent wind from blowing it around. Whatever you decide, I would contact and ask the land lord what you plan on doing.
Old 04-25-22, 04:55 AM
P
Received 1,956 Upvotes on 1,752 Posts
I would build a wood frame of treated or rot resistant lumber held in place partially by friction. Cut the vertical studs 1/6"+ (2mm+) longer than they should be so the framing is wedged between the contrete floor and ceiling. Then you can drive a few screws for extra security. Then attach your screen to this frame. You could even add a door.
Norm201 voted this post useful.
Old 04-25-22, 05:16 AM
Norm201's Avatar
I like PD's suggestion and would've suggested the same. But I have no idea how handy you might be. I do question his suggestion of screws. That ceiling looks different than what I expected. Is it hollow or does it have joists. How is it suspended. Or maybe it's just that the shinny paint makes me wonder.
Old 04-25-22, 10:32 AM
Z
Received 401 Upvotes on 356 Posts
Another idea would be to use ZipWall supports to hold up the screen. Usually it's used for plastic to cordon off a section of the house for construction, but I see no reason it couldn't hold up a large piece of screen. Easy to set up and no marks when taken down.
Something like this - though you can find off-brand ones at Amazon if you want to save a few bucks (and get something a bit cheaper):
https://www.homedepot.com/p/ZipWall-...2643/202564462
Old 04-25-22, 11:00 AM
H
Received 279 Upvotes on 239 Posts
I've managed rentals for years, - what I'd suggest is for screening is to install a screen about 2-3 feet off the edge of the porch.
Support wood lattice screening with steel U-posts driven into the lawn, hold the lattice on with zip-ties.
Could also use 4x4's anchored into the law with steel spike mailbox post anchors.
Just paint the lattice / screening / U-posts in matching color and you won't notice the different parts.
