I need some more of this lumber and I have been unable to find it at the big box stores. It has a texture and is larger than a normal 2x6... approx 1 13/16 x 5 3/4
. Does anyone know what I need to be asking for and where I may find some?
[color=#000000]I'm helping a friend replace some outside steps. We're looking for recommendations on how best get this done. I have some experience with this sort of thing, having built a deck from scratch in the past, but I am not an expert.
The current setup ([url=https://imgur.com/a/GzZAsHt]pictures[/url]) has three steps from a concrete sidewalk/slab up to a door with a metal threshold. There is an open-air crawlspace under the room with the door. The room with the door sags a bit and the amount of sagging varies throughout the year. The house is in northern New York. We get long, cold winters, so frost heave is a concern.
The existing steps are not attached to either the house or the sidewalk. They're simply resting on the sidewalk, held down with a cement block. Under the door are some deteriorating boards attached to a doubled up 2x beam. They would need to be replaced if they were going to serve as a ledger board.
Here are my initial questions:[/color]
[list]
[*][b][color=#000000]Should the steps be anchored to the house or the sidewalk?[/color][/b][color=#000000][b] [/b]I'm assuming it's not a good idea to have them floating free like they are now. And we probably wouldn't want to attach the steps to [/color][color=#000000]both[/color][color=#000000] the house and the landing, right?[/color]
[*][color=#000000]The sidewalk, the existing stairs, and the doorway are all roughly the same narrow width. [/color][b][color=#000000]Would it be possible to make the steps wider? And if so, what would that look like on the top and bottom of the stairs?[/color][/b][color=#000000][b] [/b]Would it be OK for the landing board to extend out past the edges of the sidewalk? The siding on either side of the door might be a problem.[/color]
[*][b][color=#000000]What kind of railings would be best here?[/color][/b][color=#000000] We're thinking two pressure treated 4x4 posts on each side, attached to the stringers. Would it make sense to also attach the top posts directly to the house? (And how would we do that with the siding?)[/color]
[/list]
[color=#000000]Thanks![/color]
We have a tree deck ( or tree house) supported by three trees and one post.
The structure is still good, but the floor ( 1" ply) is completely rotted. It is rotted to the point that it cannot support my weight.
I am wondering if I need to remove the ply and then put a new one or if I can put another layer of 1" ply on top of the rotthn ply? It will still be fastened to the frame under.
The reason is, to remove and put new ply, I will need to remove all the railing and then install those again. With other things and a short summer in new england, difficult to get completed.
