Questions about ledger board for stairs, slab foundation
I recently had to demo my deck because it was very rotted. I want to replace it with simple wood stairs.
I've read a bit about how to attach a new ledger board, but have questions. First I have a slab foundation so there is no getting behind this area. I've read that I shouldn't just nail a ledger board, however that seems to be how it was attached previously. FWIW it seemed structurally fine, just rotted, the deck was otherwise stable (a small deck though).
There's a good 2-3 feet of brick veneer in this area. What would be behind this brick? At some point the slab must be there, but I don't think I have 2-3 feet of concrete slab. would it just be dirt behind those bottom bricks?
Now I want to attach a new ledger board to attach wood stairs to. How should I go about this?
See the original ledger board just below the door. I imagine this must overlap with the slab, but not 100%, and the boards extending to the ground seem too low to be in front of a slab. Closer to the front of the house where the elevation is higher. After all the boards have been removed. Closer up of where the original ledger board was attached. Best I can tell it was just nailed into bricks.
Code does not allow simple steps immediately outside a exterior door. A landing is required for safety. In most cases it must be at least 36" deep in the direction of travel as you walk through the door. But, check your local codes as some areas have a 44" minimum. This means you're not building steps... your building a tiny deck and all of it's code requirements.
Attaching a ledger to brick veneer probably isn't going to be permitted. You probably need to build this freestanding which means footers and posts but talk to your local building inspections department for what they will want to see. One important issue will be how deep they want you to go with the footers. Since this is right next to the house they may require you to go until you hit virgin soil which is about as deep as the house's footers. You could get lucky and they only want you to go below frost depth.
So I guess for the original work, the ledger board being nailed to the brick was not the primary support, but rather the posts closest to the house. Those posts are in concrete (I've just cut them off for now), and the board was resting on top of them, in addition to being nailed into brick. Does that make sense? I'm just trying to understand the old work relative to what I need to do now.
Your old structure may have been belt and suspenders. Supported from both the posts in the ground and the members nailed to the brick.
A lot of things were acceptable long ago but are no longer permitted. Your steps lasting so long shows that unapproved methods can work. But, especially with decks where there have been numerous collapses that have killed and injured people the codes take deck support and attachment to a house VERY seriously now. And, they don't differentiate between a large deck two stories off the ground and a simple landing two feet off the ground.
Those three boards below the ledger where there to prevent the ledger nails from shearing off
by supporting/distributing most of the weight.
I'd say the ledger was supporting the old deck.
It looks like you already had a mini deck there.
Hard to comment on the posts in the ground as they aren't seen.
If I understand this correctly, I should be able to build just stairs with no landing, because the door in question is not the "required egress door" (it's the back door, accessible from the kitchen), and the door doesn't swing out over the stairs (it's a sliding door). Do you agree with this interpretation?
Don't ask me why, but I thought I'd build a 10x10 deck with no footers at all, just 4 4x4 posts set in packed gravel, sunk beneath the frost line. So I've already dug the holes, tamped some gravel in the bottom, plumbed the posts, set the beams, installed K-braces, and even hung the first few joists so the whole structure is now pretty self-stable, square, and level. Now that this whole framework is erect and sitting in empty holes waiting to be filled with gravel, I've finally started to worry that these skinny little legs don't have enough surface contact with the Earth to resist sinking under the weight of the completed deck:( I feel like a doofus, but want to know if there's any way to save this project without completely dismantling everything I've already built? If you were me, what would you do?:
1. Take it all apart, install proper footers, and rebuild.
2. Somehow dig beneath the existing posts and install footers under them?
3. Pour concrete in the existing holes, AROUND the posts (sloping the top of the concrete to shed water away from the post)?
4. Leave it how it is. The tamped gravel base will likely resist settling?
I'm obviously hoping #4 is the way to go, saving labor and embarrassment, but please tell me what you think. Thanks in advance for your guidance.
I bought a small cabin in East Texas. It needs quite a bit of work but i'm fairly handy and able. It has a covered front porch that is tied to the roof but has a smaller slope. The shingles began leaking at some point and the decking is rotted and needs to be replaced. I'm going to replace the roof as well so when i remove all the shingle i'll tackle this job. My question is, what is the proper way to tie on and transition a covered porch to an existing roof?
