We have some pretty wide cracks in our brick stairs leading up to the front door. Cracks may not be the right word - more the grout is separating from the brick. How do I go about fixing this? And are there different colors of grout so that I can make the fixes sorta match the rest of the stairs. Not sure if grout is the right word either. thanks.
Reason: change notification settings
That's mortar. It needs to be re-pointed.
Until they become a lot more disintegrated, I would go to the hardware store and buy mortar mix patch. It comes in a tube. Unless you want to chip out all the old stuff.
That is not grout. It is mortar that holds the bricks together. Yours has cracked, likely due to movement. A long term fix is not easy (and probably not needed) since it's likely the footer/foundation that is the cause so it can't be totally fixed without a lot of work. A mid level repair would be to grind the mortar out the joints that are cracked and repoint with new mortar. The lowest level would be to use a caulk to fill the cracks.
Mortar exists in many, many colors. Yours looks natural but it's color is affected by the type of sand used and the mixing ratio. There is no "go buy this package" advice. If you want a match you've got to do the work to recreate the original recipe including finding a sand of a similar color and texture and mix up some sample batches until you find a good recipe. But, your mortar looks pretty standard so I don't think I'd bother and I would use a standard mix.
If doing anything with mortar it is very important to keep it off of the face of the bricks. A blob of mortar falling on the brick, even if you wipe it off, will probably leave a white mortar stain on the brick when it dries so it's best to keep it clean instead of trying to clean it off after the fact.
Hello. I need to replace a couple of damaged spindles on a porch railing. The existing spindles are exactly 1" square with the sharp square edges (not rounded) and 32" long. These are just plain square spindles, no turnings or other decorative work. The thinnest (?) pressure treated spindles available at local (Chicagoland) big box stores, lumber yards and decking supply stores are 2x2s with rounded edges.
I am trying to avoid having to replace the entire railing (there are two of these) just for a couple of spindles. Any help regarding where I might find 1" (exactly) square wood spindles in Chicagoland or online is much appreciated. Thanks in advance.Read More
I stained my deck in 2020. The vertical surfaces look great, but flat surface with foot traffic has not aged well. I have one can of stain left from 2020 (enough to cover the areas that are in bad shape). Is it okay to just stain on top of the old stain? My hope is to get one or two more summers out of the deck before I sand it and choose a better stain next time around. The stain that I used (pictured below) doesn't exist anymore anyways. Thanks
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/620x465/deck_stain_5599eb02b8ca003c9cc6d6502bc63e5c0d490cf1.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/620x465/stain_20d8827d2a421cb550ba74ed1e1103a5da2c8164.jpg[/img]
Read More
