How to Sister 2x10's
I have a deck which is 36 feet long. It has piers every 6 feet, therefore the joist span is 6 feet. How do I sister the 2x10 together. I am going to use 12-foot length boards. What do you suggest: Nails, Lag screws, or bolts. What size how far apart? How far from the top and bottom edges and ends? If you suggest lag bolts what size pilot holes?
Assuming you have 7 piers.Your support beam will consist of three 12 ft boards on one side and two 12 ft and two 6 ft (one each end) on the other side. All butt joints fall on a pier. Use pressure treated boards and galvanized attaching hardware. I am not qualified to suggest size and location of attaching hardware.
Your codes will specify what fastening they want when building a beam. You didn't say where you are located but some areas have stricter or different requirements. You can look at the International Building Codes (IBC) for a start. Also, since decks are often a DIY project and are often done wrong... many building inspection departments have a flyer prepared to guide you through the most common problem areas like; footings, how to attach to the house, stairs, railings, beam requirements...
The code might say that you need a minimum of four 3" long nails evenly spaced in a line across the beam from both sides. Each row of nails every 16".
