Deck Ledger Board Bolts to House
Old 02-17-23, 12:28 PM
A
I have a deck which is 36 long and needing to attach the ledge board to the house which is on concrete blocks 4 feet high. The ledger board is 2ea 2x10 sister together, The ledger board is supported by piers 6 feet apart on the deck side. What size bolts, the width and length of the ledger board on the side underneath the house and spacing of the bolts?
Old 02-17-23, 02:57 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
Your description may be clear to you, but we need a photo to ensure we understand the construction and your description. In the meantime, download the DCA6 Prescriptive Deck Guide and follow it's instructions for your project. If you have additional questions just ask.
Old 02-17-23, 06:01 PM
A
Attached is a picture. I will be using 2x8's on 16" centers and use hurricane hangers to attach to 2x10 sistered together and attached to the house. Composite decking will be placed on top for termite protection since it is close to the sand. Also Termix protection. The sand is about 2-3 deep. Has a slope so I will take out a couple of bricks to aid in the drainage. Open to all suggestions. I did a search for the DCA6 but it did not find anything.....https://www.flickr.com/photos/771598...posted-public/.....
Old 02-17-23, 06:32 PM
XSleeper's Avatar
DCA6 Prescriptive Deck Guide. It is literally the first result if you Google it.
https://cms7files.revize.com/waterto...Guide-1804.pdf
What exactly is the ledger bolting to, can't tell from the photo. Wood? Concrete block? The bolts will be located 2" from the top and bottom of the ledger. And what's the point of doubling your ledger?
Old 02-19-23, 08:49 AM
Received 1,231 Upvotes on 1,179 Posts
Honestly, that close to the ground, I would pour a patio.
