I have a 13*13 deck area that has a storage basement below. The top is waterproofed with membrane with a 2% slope away from the house. Can I put decking wood (treated or engineered) directly on the membrane without leaving a gap?
I'm wondering how it will hold up if water gets between the wood and membrane.
Wood is not a good option. All wood decks need proper airflow so the wood can dry. If it stays wet, like a deck built on grade or on top of a solid surface like you have the wood will rot prematurely. Usually with a area like that it is covered with a waterproofing membrane that is designed to be walked. It's stronger than normal roofing membrane and is textured on the top so it's not slippery. It's available in different colors and can have speckled or other decorative patterns. You can also cover the area with outdoor carpet.
Lol
I would like it to look like a deck not roofing membrane or carpet if possible
So I guess tile or engineered plastic faux wood then
Or create an air gap somehow
What about if the wood interlocked tightly and was waterproofed
I am a FIRM believer in composite material for any outdoor deck (like) project. With composite you do not have any concerns of water/rot issues, none!
To that a deck structure that provided some space between you membrane and the decking material will do nothing but improve the longevity of all materials!
Keep in mind that anything you fasten through the membrane can compromise the water-proof-ness. You may want to look at the composite floating deck tiles if the surface is relatively flat. You would just need a lip around the edge to keep them in place, and they can be lifted up if necessary to clean out leaf litter or the like that will inevitably get underneath.
I am wanting to buy a couple cheapo cat shelters for the neighborhood throwaways. How can I attach this cat shelter to the patio deck without risking my damage deposit?
[url]https://www.walmart.com/ip/Outdoor-Cat-House-Waterproof-Warm-Cat-House-for-Outdoor-Indoor-Cats-Feral-Cat-Shelter-with-Removable-Soft-Mat-Warm-Dog-House-for-Small-Dogs/3934796361?[/url]
According to the reviews, it is so lightweight any wind will carry it off, and the wind here is furious!
Read More
Spring scrub down and found 2 interesting items, the first was a pile of something on one of the steps, in the corner. Wasn't dirt, saw dust like, but inspecting top and bottom no sign of any damage, it's all PT amd composite. Almost looks like the material was brought to that spot but by what?
2nd item I actually noticed late last year, kind of looks like something was chewing on one of the posts, do those look like teeth marks? What the heck chews on PT posts?
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20230415_090008_1aa188a49fe3612ff7ba8866a7ac6b4f3aae14dd.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/20230415_090017_ae4e4af8deb864aef9ef57e4d66cb0c19964f880.jpg[/img]Read More
