Footing spacing around utility lines
Old 06-10-23, 11:27 AM
B
Hello. I'm building my own deck. I've got pretty detailed plans put together, but when I laid the plans out I discovered one of the footings under the beam was dangerously close to the utility (electrical and internet) lines coming into the house. I'm curious what opinions others might have on how to get around this. Here is a snapshot of the footing arrangement with my notes ... I'm curious if it's considered bad structurally to have the footings spaced wider at one point in order to get around utility like I need to. You can see how I'm considering doubling up the 6x6s to the "left" of the utility lines in the photo below, and then just moving the remainder over on the "right". This would result in a gap around the utility lines.
So long as I get the tributary widths and all of that figured out, and the footings sized appropriately, do you see any issues with this? Any other cleverer ideas?
Thanks.
Old 06-10-23, 12:16 PM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
So where they exist is sort of an estimate, no mater how they were mapped (assuming miss digg?) all I would do is carefully hand dig the one where the one post is next to the lines and not change anything!.
Thinking more, Id probably hand dig several of them to find the wires and then you know your good to go!
Benjamin Rush voted this post useful.
Old 06-10-23, 01:01 PM
B
Hey buddy, thanks.
The city utilities come out and spray paint where the lines are located. A contractor friend of mine echoed basically what you're saying: it's just a guestimate no matter what, and you often have to give a foot or more on either side of their lines.
I'm assuming the general idea of spreading out the footings along the beam is a bad one? What if it happens that I am getting dangerously close to one? Is it alright to move the footing around a foot or so one direction or another? Or do the posts have to have nearly identical spacing?
Old 06-10-23, 10:54 PM
Marq1's Avatar
If it has to move then it has to move but once you find the cable even if its dead center your only moving a few inches, the amount of support doesn't change and the spacing is not so critical that a few inches is going to create issues.
