Help with leaning carport
Old 04-01-02, 01:24 PM
R
rtfunshots
In recent years my carport has been leaning to one side. It has gotten to the point where I'm afraid it is gonna come down with a good burst of wind soon. It sits on 4 support posts, one on each corner but it has no bracketing on top. I have no idea on how to begen to repair this. Would appreciate any instruction I can get. Thanks.
Old 04-05-02, 02:21 PM
josh1
is this a wooden carport?
if the corner posts are something like 4x4s i suggest you make 45 degree "triangle brackets 8 of them for all 4 corners.. then as best you can.. winch the posts to .. a tree or something and pull them into vertical with a level..then screw these 45s onto the post and into the top rail of the roof section... this should help with stability loads...
Hope this helps---Josh
ps nothing is handier than a 2 ton hand pull winch! nothing!
