oil based vs water based stains
Old 07-24-02, 12:10 PM
nvsmom
Is there really a difference between oil based and water based stains? Besides clean-up? Does one last longer then the other, especially green treated? I hate using oil based anything because of the clean up. I just throw away the brush and the roller when I am done. I am trying to get my front porch stained (its been a year) and didnt realize that there is so many choices in everything. Come on guys, my husband really doesnt know much about it. And since i will be the one to stain it, i dont want to do it every year (or every other). Thanx, Tina
Old 07-24-02, 01:32 PM
fewalt's Avatar
Hi Tina,
Well, water base stains aren't worth squat. Neither are any clear sealers.
Get a good oil-base stain with some color (cedar, redwood, etc,),
and one which is water repellent and has UV protection(Cabots, Sikkens, or Wolmans F&P). These thee are the top rated by Consumer Report. The uv protection is in the color oxide pigments.
And it doesn't take expensive rollers or brushes, so clean-up is a mute point. Three dollar brushes - use and toss.
fred
PS - your porch should be cleaned/pw prior to staining.
Old 07-24-02, 06:12 PM
nvsmom
stains
Thanx Fred, knew i could count on you for the right stuff. thanx again! tina
