Outlet covers
Old 09-07-04, 11:24 AM
Millipede
Outlet covers
My living room and dining room are both very dark colors, with white trim and ceilings. I decided to leave the lightswitch and outlet covers white, but now I'm rethinking that choice.
I like the white switchplates, because having them stand out seems to work. But I can't make up my mind about the outlets. The ones in the living room are mostly hidden by furniture. The ones in the dining room are not hidden at all.
Opinions?
- Millipede
Old 09-07-04, 11:34 AM
Annette's Avatar
if your walls are wallpapered, then i'd cover them (and the switchplates) with the wallpaper, exactly matching the pattern.
but if the walls are just painted, i wouldn't paint them. painted covers look weird. however, you could change them to something less contrasting, like maybe brass or nickel or wood, etc - whatever would work in your space.
whatever you do, i'd treat both the outlets & switchplates the same.
Old 09-08-04, 07:07 AM
Millipede
The walls are painted, not wallpaper.
I should have mentioned that I already have a decorative pewter lightswitch cover in the dining room, so matching the outlet covers isn't possible. I suppose I could do brushed nickel covers, which would sort of match (the furniture is pewter-look as well).
- Millipede
