stepping stones
Old 10-12-00, 05:47 PM
Guest
Post
Can anyone tell me how to make stepping stones???
Old 10-15-00, 04:34 AM
Guest
Post
Make a form out of wood and plywood OR buy a form in plastic you like. Available at craft and build all stores.
Use either quick crete or a mortor, sand, water mix to make your own mixture.
Decorate with stones, pressed in leaves, glass pebbles and marbles etc. as you like.
Let dry, seal with spar varnish or just leave them to age.
Hope this helps
Rainie
Old 10-15-00, 11:33 AM
Post
Rainie pretty much said it all. I would add only that if you make the form out of wood, slant the sides out slightly to make it easier to get the product out of the form (s). Also, oil the inside of the form each time it's used to keep the concrete from sticking to the wood. Light motor oil will work.
John
