ultra strong, reusable double-sided tape?
Old 12-30-14, 01:37 AM
D
Is there such a thing? The best I've used so far (ironically, not Scotch/3M) is MT Tape. Is there anything that is more durable and stronger?
thank you so much!
Old 12-30-14, 04:02 AM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Double sided tape isn't meant to be "reused". Why must you reuse it? Have you tried velcro strips?
Old 12-30-14, 08:01 AM
Received 1,287 Upvotes on 1,225 Posts
I can't see Strong and Reusable applying to the same product.
What is it you're actually trying to accomplish?
Old 01-18-15, 04:43 AM
D
For instance, when I am doing photography shoots, I need to stick my 60" round reflector to a wall/whatever vertical surface I can find. It needs to be flexible enough, hence velcro strips wouldn't work (unless it is a permanent location we're talking about).
Old 01-18-15, 05:17 AM
P
Received 2,309 Upvotes on 2,054 Posts
I use spring clamps.
Old 01-18-15, 06:23 AM
How heavy is your reflector? If it's very light, you might try that tacky putty stuff (blue-tack?) that's recommended for college dorms. It sticks lightweight items up very well but can be removed without damaging the wall and reused.
