Plumbing hardware question
Old 08-12-02, 03:27 PM
gdavis
Question Plumbing hardware question
I had to remove and re-install a one piece fiberglass shower stall,
a chore in itself, since it was originally installed poorly. I
would like to add a second showerhead (or handheld) to the opposite
wall from the first, and have a valve that lets me select either
one or the other or both at once. Does such a valve exist? Where
might I be able to find one?
Thank you
Old 08-12-02, 07:43 PM
Doug Aleshire's Avatar
Dual Showerheads
gdavis,
Hopefully these sites will address the isues you want to know more about;
http://www.plumbingsupply.com/grohec...owers.html#abc
http://www.keidel.com/design/select/showers-custom.htm
Good Luck!
