bathroom vent
Old 08-18-02, 04:11 PM
locolobo
bathroom vent
Probably a dumb question that will be answered when I buy the fan but When installing a fan in a bathroom, do you vent it into the attic or up through the roof? Thanks
Old 08-18-02, 08:06 PM
Doug Aleshire's Avatar
bathroom exhaust fan venting
locolobo,
You should never exhaust air into spaces within walls, ceilings, attics, crawl spaces or garages. The humidity may damage the structure and insulation. Venting is usually done through the roof or wall. Applications will be based on your current site conditions.
You're right, the instructions in the box will direct you to how to install.
Hope this helps!
Old 08-19-02, 08:35 PM
locolobo
Thanks Doug, I looked into it a little bit and I will probably vent it out through the soffit. Thanks again. locolobo
Old 08-20-02, 07:12 AM
WhatandHow
venting via soffit
The soffit is the roof over-hang outside, correct?
Are there pros/cons to exhaustiung the fan here? I have a tin roof and don't want to have go that route.
Thanks
Old 08-20-02, 07:36 AM
venting via soffit
WhatandHow,
I'm not in favor of going through soffits but to each his own. I prefer to go through a roof or side wall. Even on homes with Brick exterior the installation is not hard. Only issue is running electrical but even then it's easy. With various venting caps available, there are colors available or break out the can of spray paint.
Hope this helps!
