converting plumbing from a tub to a shower.
Please help me with any info at all that will help me convert my plumbing from our 1pc tub stall to a double stand up shower. We have already removed the tub and now not sure how to make sure the plumbing is correct for the shower, as far as knobs and moving to a center drain for the shower. I dont know if this make sense or not. But I am a little flustered. Thanks, Maseymo
Tub to shower
maseymo,
Not sure if this is a basement or main floor install, the applications will accomodate both. I also have attached a fiberglass base and wall unit links. I have attached links that should direct you without getting into trouble.
http://www.asilo.com/house/shower-plumbing.html
http://www.plumberpages.com/plumbing/plumbshowers.htm
http://www.theswancorp.com/showerfloors.html
http://www.asbcorp.com/index.cfm
http://www.elmustee.com/showerwall.html
Hope this helps!
Hope this helps!
