shower remodel
Old 09-12-02, 10:14 AM
jerone
shower remodel
hi guys,
i need your help.i had a tiled shower that was totally destroyed by leakage thru the window.i had to bust out the tile wall to remove the moisture ants and repair the damaged wood.heres the problem....the shower is larger than a regular shower(60x38).i can't buy a 3 pc fiberglass shower cus they won't fit thru my doors.i had a estimate from a tiler and it was $800 before materials and buying the custom shower base.What is the BEST way for me to go???????????
i appreciate any advice......
thanks
Old 09-12-02, 03:17 PM
chukmac
shower
Jerome, I would check with cultured marble shower mfgrs and see what their prices are. The one where I live have one approx that size with a seat in it. Looked good,but I was looking at tubs.Hope this helps-chuck
Old 09-12-02, 07:34 PM
Doug Aleshire's Avatar
Shower Replacement
jerone,
I haven't found any projects yet whereby the remodeler kits can't be introduced into a bathroom. I have attached 3 links, just take a look and see if they would work for you;
http://www.maax.com/pdf_technique/us/SOPRAN1.PDF
http://www.theswancorp.com/
http://www.us.kohler.com/onlinecatalog/pdf/113522_4.pdf
Hope they help!
