shower pan on cement floor
Old 09-27-02, 09:03 AM
massageman
I am installing a new shower pan on a cement floor. Everything I have read talks about stapling roofing paper down first. Do I need to put anything down before I do my first layer of cement?
Thanks
Old 09-29-02, 08:12 PM
Doug Aleshire's Avatar
massageman,
I have attached some links that explain everything the right way. Roofing paper is usually done over a wood subfloor and even then that is not the right way for a shower. It is for major flooring areas besides high moisture areas. Old days..yes, now days..NO.
http://web.archive.org/web/200108022...ers/index.html
http://www.johnbridge.com/mortar_bed_shower_floor.htm
http://www.schluter.com/english/prod...802-index.html
http://www.johnbridge.com/shower_pan_replacement.htm
http://www.bedrosians.com/tca5.htm
Hope this helps you out, it will be easier now!
