fiber glass shower wall with holes
I have a fiber glass shower and when I moved in the shower must have had sliding doors and then were taken off. After they took off the doors they left the holes open on the sides where the hinges must have been. How do I fill in the holes? Is there a plug or something I can buy for this? I've seen a couple of ants also and wanted to know if I should spray inside the holes first. THe ants haven't shown up in a week so I didn't know if that was an issue. I live in a condo. Thanks for your help.
fast and easy fix - coat an appropriately sized screw with silicone and screw them into the hole.
Best fix - call a surface repair company to fix with fiberglass and recoat with gelcoat.
You might also try a home fiberglass repair kit.
Good luck
Bob
Good luck
Bob
