Installing bathroom in basement
Old 10-11-02, 11:48 AM
swafalosky
How do I attach the Duraock to the studs and what do I use to put tile on the Durarock ... thin set ?.... do I need to use Durarock all around the shower stall / ... would it be cheaper/ easier just to use a plastic surround. thks much Steve:
Old 10-11-02, 04:45 PM
Doug Aleshire's Avatar
swafalosky,
Issue is what do YOU want? If you like tile do it in tile, if you like surrounds, do that. I have attached some links to tile backers and tile installation how to's;
http://interiordec.about.com/gi/dyna...2Fdoityour.htm
http://www.floorstransformed.com/backerboard.html
http://www.hardibacker.com/hardibackerinstall.htm
http://interiordec.about.com/cs/tileinstallation/
http://www.c-cure.com/servref/brochar/47htm/f47.htm
If you are interested in surrounds, here are some links;
http://www.theswancorp.com/
http://www.elmustee.com/bathwall.html
http://www.asbcorp.com/index.cfm
Compare costs, features and benefits of either tile or surrounds, make your decision based on what you like.
Hope this helps!
Old 10-12-02, 05:45 AM
swafalosky
Very helpfull ,thank you for your assistance.
Old 10-12-02, 08:09 AM
michaelshortt's Avatar
A lot of builders prefer to use the plastic shower and tub enclosures. They have fewer call backs for leaks and tile repair.
