renewin the drywall in mybathroom
my bathroom drywall seems to be falling out the tile is still applied to it but u can push in the drywall how can i go about fixing this project ?
Drywall failure
Sounds like moisture has penetrated through the tile grout and caused deterioration of the drywall. There is no quick fix. The damaged drywall should be removed and areas behind inspected for moisture damage. Concrete underlayment board is recommended in tub/shower areas. Greenboard, drywall with water resistant coating, can be installed on other walls for additional protection.
