Bathroom floor squeaks and squawks
We recently redid our bathroom replacing everything. We ripped out the old K3 subfloor and swept it well. We then layed new plywood good side and screwed it well down. It now squawks and squeaks right in fron of the vanity and is driving me nuts . does anyone have any idea what we could do short of ripping it up. Also maybe tips on what we did wrong ? Any ideas please
Squeaky subfloor
Fixing a Squeaky Floor
Squeaky floors driving you crazy? These easy, surefire fixes will quiet noisy hardwood and carpeted floors.
by Merle Henkenius
Repairs from below
If the floor is over a basement or crawl space, go below to make the repairs. Start by having someone walk across the floor while you listen from below. When you hear a squeak, have the person above rap on the floor so you can pinpoint the exact spot. Next, take a thin wood shim and coat it with carpenter's glue. Gently tap the shim into the space between the joist and subfloor. Don't drive it in too far because you will raise the flooring. You just want to fill the gap above the joist and take out any "give" in the floor. For additional support, drive a 1 1/4-in. drywall screw at an angle up through the joist and shim and into the subfloor.
Another effective way to silence floors from below is with a cleverly designed piece of hardware called the Squeak-Ender ($7). It consists of a threaded rod attached to a flat mounting plate and a steel bracket fitted with a squared-off hook on one end. Installation is easy:
Screw the mounting plate to the underside of the subfloor with the four screws provided. Position it directly under the squeaky spot. Slide the bracket over the threaded rod and hook it onto the joist. Spin a nut onto the rod, then tighten it with a wrench until the subfloor is pulled down snug against the joist.
Hold-down bracket
1. Hold the Squeak-Ender's steel mounting plate against the joist, then screw it to the plywood subfloor.
2. Tighten the nut with a wrench until the subfloor is pulled down snug against the floor joist.
Glue-coated Shims
1. Tap a wood shim into the gap above the floor joist after smearing the shim with carpenter's glue.
2. Drive a drywall screw at an angle up through the joist and shim and into the plywood subfloor above.
<PREVIOUS | NEXT: Working from Above
1 | 2 | 3 | 4 | 5 Click through these pages for additional info!
Repair & Maintenance. This Old House Online. Retrieved 13 October 2002. http://www.thisoldhouse.com/toh/repa...3171-2,00.html
by Merle Henkenius
Repairs from below
Hold-down bracket
Glue-coated Shims
