bathtub replacement
bathtub replacement
Took out a standing tiled shower and am replacing with iron tub. As part of this project, I am remodeling entire bathroom down to the 1"X6" subfloor. I plan on using duroroc as subsurface for floor and wall yet don't know what should go under the tub. Any thoughts?
crisikius,
Normally, your subfloor will be the only thing required under the tub, nothing else. When the tub is installed, the durock should butt right up against it, then your tile over it.
Good luck!
Good luck!
kk007,
Normally with a cast iron tub nothing is required beneath it but I wouldn't think putting a 5 gallon pail of Joint Compound under the bottom would hurt anything. It will be a solid base support!
You got me wondering what you are doing. If you are going to use Durock over the subfloor, then using thinset would be used for floor tiles. This is much easier, extremely solid and no mess.
If you are talking about a mud base floor system, i.e. 30# felt paper, metal lath and sand/concrete mix then your tile, there is no need for the Durock on the floor as this system doesn't require it. This takes time, mud base must be level and is a harder process.
Hope this helps!
Hope this helps!
brickeyee,
Just to help you out, the use of mortar or plaster (joint compound) is RECOMMENDED for tubs, whirlpools and shower pans by Jacuzzi, Lasco and American Standard. Some Kohler models recommend it but few. I've done alot of these, check out their installation manuals, you'll be surprised.
As I said and you agreed, most steel tubs do not need additional support but there are some flimsy ones out there.
Once joint compound is hard, placing it in water doesn't make it go soft in minutes. This stuff is pretty hard! Besides, if you had that much water under a tub, something is really wrong!
Hope this helps!
Hope this helps!
And what does the drywall compound company have to say? The joint compound I used to use goes soft so fast you can wet sand it. And if you are not carefull make divots. I would use mortar. there is a time and a place for adapting materials. Since a superior material is easily available, I do not think this is it.
