glass block knee wall
Old 02-22-03, 06:05 PM
moe707
I want to build a knee wall out of glass blocks in my new bathroom. I never done this before, I watched a tape on building a glass block wall but all of the instructions were related to a framed in glass block system. All had four framed sides. My knee wall will have only two (floor and the one vertical jamb side).
1) Can I build a non bearing glass block knee wall relying on just to sides?
2) If the answer ti 1 is yes, what is the best way to anchor the one jamb side to the studs and the bottom side to the floor?
3) Can I use the so called Mortarless glass block installation?
Thank you for your help.
Moe
Old 02-22-03, 06:13 PM
Doug Aleshire's Avatar
moe707,
Try these links;
http://www.pittsburghcorning.com/homeowners/faq1.asp
http://www.pittsburghcorning.com/hom...stepbystep.asp
http://www.glassmasonry.com/details.html
It may be necessary for you to contact a local glass block company or supplier to get information on current accessories necessary to achieve what you are wanting.
Hope this helps!
