Solder w/ valve seat in place?
Old 03-19-03, 07:59 PM
D
Question Solder w/ valve seat in place?
I'm going to solder 1/2" copper lines to a pair of roman tub valves. I'm going to remove the valve stem before soldering. The stem has a compression washer at the end, probably made of rubber. Should I also remove the valve seat? Would it be any more difficult to remove the seat later if I solder with it in place?
Do I need a different flux because of brass valve body and copper lines?
Old 03-19-03, 08:21 PM
mattison's Avatar
If it's indeed rubber it would be best to take it out if you can't wrap it with a wet rag.
As for solder it's not the flux. You want to use silver solder.
Old 03-20-03, 09:53 AM
D
Silver solder a plumbing fixture? What about the valve seat? Is it better to remove or leave in place?
Old 03-20-03, 01:10 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
You don't need to remove a valve seat to solder, and just use lead-free solder for water supply.
Good Luck!
Mike
Old 03-20-03, 01:25 PM
mattison's Avatar
Sorry, I do mostly HVAC when you go brass to copper I use silver solder it flows and sticks to brass better.But of course I'm brazing not soldering.
Old 03-20-03, 09:21 PM
D
Thanks for the info and clarification.
