Solid Material tub surround
Old 03-31-03, 07:35 AM
Cwilliams
I will be installing a marbelite (solid material) tub surround, what is the best material to attached to the studs behind it, cement board or green board?
Old 03-31-03, 08:31 PM
Doug Aleshire's Avatar
Cwilliams,
I think this will help, it is solid surface material so it will be similar. Personally, I would do just greenboard.
http://www.theswancorp.com/Library/PDFs/FORM252.pdf
Hope this helps!
Old 04-01-03, 06:33 AM
Cwilliams
Thanks Doug for the link, I was hoping that greenboard would work. I appreciate the quick response.
