backerboard wall seams?
Old 04-05-03, 08:00 AM
sktracy
Hi,
I have all the backerboard up around my tub. I've been trying to figure out what I need to do with the seams (between backerboards, between backerboard and drywall).
I've seen a lot of different suggestions. What's the best solution?
Thanks,
Steve
Old 04-05-03, 06:16 PM
Doug Aleshire's Avatar
Steve,
I would apply tape and joint compound. Since you are going to tile, do a good job where the tile stops and drywall begins so your painting will look awesome. NOTE: I assume that the backboard is sitting on top of the tub nailing flange? You don't want this over it and "bulging" out or your tiling job will look terrible!
The joints under the tile just need to be "fire-taped", one coat basically - nothing fancy that requires a 3 coat process- unneccessary. Just make do a one swipe with trowel so it's fairly smooth - no need to sand it.
I assume this is what you are asking?
Old 04-07-03, 09:55 AM
sugarbeth
Tape and thin-set mortar between cement backerboard joints, tape and joint compound between drywall/backerboard seams.
