cement board/duroc
Old 06-29-00, 04:55 PM
Guest
Question
What is used to seal the seams/corners on duroc after install in tub-shower space?
Old 06-30-00, 08:04 AM
Guest
Post
silicone tile adhesive caulking.
quote:<HR>Originally posted by dayve:
What is used to seal the seams/corners on duroc after install in tub-shower space?<HR>
Old 06-30-00, 08:07 AM
Guest
Post
I thought the answer was thinset mortar and special fiberglass tape (not the kind used for drywall).
Old 06-30-00, 01:52 PM
Guest
Post
Newcote is right. Only silicone caulk. It comes in clear or white. Sometimes it is called bathroom tile silicone caulk.
Old 07-05-00, 06:51 AM
Guest
Post
I think I interpreted the question differently than you did. I thought the question was asking about the seam between one Durock panel and another Durock panel. If I interpreted correctly, then I note that the label on each Durock panel, and the United States Gypsum Company web site at http://www.usg.com/diycb/diycb3.htm says to fill joints with tile-setting mortar. Does perhaps the answer further depend on whether you're using mortar or mastic to attach your tile?
Old 07-06-00, 05:36 PM
Guest
Post
All this helps..thanks
