Shower enclosure
Old 07-01-03, 12:17 PM
wdhucksjr
Shower enclosure
I have an odd dimensioned shower that I want to install a new shower enclosure in. The one or two piece units will not fit the dimensions very well and another option I am aware of is to use the panelized shower wall systems. Someone has suggested to me the option of using fiberglass reinforced panels (FRP, commonly used in commercial kitchens and restrooms as a wall finish) with the associated trim pieces as a less expensive option to the panelized systems. However, I am suspect of the FRP trim pieces ability to keep out the water. Has anyone had a successful experience using FRP as an actual shower enclosure?
Thanks!
Old 07-01-03, 10:45 PM
Doug Aleshire's Avatar
wdhucksjr,
Take a look at these...
http://www.ambath.com/home.htm
http://www.mustee.com/index.html
I cannot help you with the FRP but these are great as you can make cuts to fit.
Good Luck!
