plumbing
Old 09-12-03, 05:10 PM
joannes332
plumbing
how do I lower the water level in the tank to my toilet
Old 09-12-03, 05:14 PM
If the fill valve in the toilet has a float ball: turn screw clockwise to lower water on top of fill valve.
If the fill valve in the toilet has a moving canister on a rod: Adjust metal clip down on rod to keep canister from raising. Fluidmaster 400A is what I am talking about.
Old 09-18-03, 01:41 PM
jrizzo17
if you mean to use less water...just fill an old pickle jar full of water and set it in...it will force the water level up so you use less water with every flush.
John
Old 09-18-03, 05:08 PM
joannes332
Toilet running
Thanks to all of you for your help. Nothing I did worked so ended up calling a plumber who had to install new insides to tank - fluidmaster.
