moving toliet in bathroom
Old 09-17-03, 01:54 PM
Mr_Funkenstien
is it a big deal to move a toliet in a bathroom. right now it sits about 3 feet from the entry side of the bathtub. to make better use of the space i would consider moving it so it ends up behind and right next to the shower head.
thanks for you help
brian
Old 09-17-03, 07:53 PM
I_do_it_all
Moving toilet in bathroom
You'll have to relocate the 4"waste pipe from its current location to where you want it, as well as water supply line for the flush tank. If your current water supply to the flush tank comes up through the floor it makes it a little easier as you can run the new line form there to the new location.
It is quite a large job and if you haven't done anything like this before, it will be challenging. You'll also have to patch up the old location, of course.
Hope this helps and good luck.
