Plumbing
Old 10-15-03, 02:50 PM
rdinkins
Thumbs up Plumbing
using cpvc male coupling going to a female metal coupling. what is the best thing to use if it still leaks. I used teflon tape but it stills leaks a little:
Old 10-15-03, 04:47 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
Wrap 3-4 flat wraps of teflon tape around the male threads clockwise only as the threaded end faces you.
If that doesn't stop the leaking, you also can smear a little silicone caulk on the threads to seal it.
Good Luck!
