Misplaced toilet installation
Old 10-15-03, 09:33 PM
bobdino1
Angry Misplaced toilet installation
Even after checking and rechecking I managed to set the rough framing at 12" instead of 12.5" fromthe center of the toilet flange.
What can I do to rectify this mistake? (Wallboard is now up and tub installed)
Need advice badly!!
Old 10-16-03, 07:14 AM
There should be enough 'slop' in the various components to allow it to work. Try fitting the toilet.
I am assuming the flange hole is precise and the plumbing unable to allow the flange to be moved. If you can budge the flange a bit, that helps also.
Test-fit the toilet, tank and all. What does it look like?
Old 10-16-03, 11:03 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Toilet will set at 12" to center, tank lid may seem tight to wall but it will work.
