corian sink installation
Old 02-07-04, 06:06 PM
H
We are installing two Corian Sinks in our bathroom. On the one sink we ordered a side splash an inch to long as it butts up to a side of a cupboard which isn't as deep as the sink.
I know you can drill and sand corian but could I also cut off an inch with a miter saw and then sand then end to make it smooth?
Or is there a different way to do this?
Thanks.
Harlan
Old 02-07-04, 06:09 PM
jeremy1tn
Corian Cutting
I would recommend that you use a special router bit made for cutting the corian. A chance of damaging it, makes it well worth buying the right tools.
Old 02-07-04, 06:52 PM
Dave_D1945's Avatar
Received 1 Upvote on 1 Post
Corian can be worked with standard wood working tools using carbide blades or bits. It took me at least five minutes to work up the nerve to run a piece of Corian thru my table saw a few years ago. I was totally amazed at how easily it cut.
Don't even think of trying to cut it with steel blades or bits.
Old 02-09-04, 12:42 PM
H
Thanks for the information. I put in a new carbide tip blade in miter saw and sawed it last night. It work perfect. Nice and smooth.
Harlan
