scratched CORIAN
Old 03-04-04, 08:17 PM
scratched CORIAN
What is the best way to take scratches out of CORIAN?
Old 03-06-04, 07:36 AM
T
Received 2 Upvotes on 2 Posts
Corian
Most stains and scratches can be buffed out of Corian. The finest grit sanding pads can be used to remove the scratches. (The color of the pads from roughest to smoothest are: White, Yellow, Green, Peach, Lilac, Blue, Gray.)
Rub scratch in a straight line and switch occasionally to rub at a 90 angle to scratch. Buff out all of the scratch. Use heavier grit pad if the process is going too slow. Keep surface wet while sanding to minimize dust and keep pad rinsed. Clean top with water. If sanding required a heavier grit, work your way back down to the finest grit and finally rub over a larger area to blend in the sanding. Continue with lightest grit until desired gloss is restored.
Old 03-13-04, 08:16 PM
Thank You!
